if I understand right, the Octane rounded edge function is a mesh manipulation. Why not a shader based edge softening? I never used shader based edge softening. If I understand right it's based on ambient occlusion calculations. Maybe there are some reason why it is not implemented. Or is it on the way? My hope is to get smooth edges without the limits of mesh manipulated soft edges.
Ciao,
Micha
Rounded edge by shader?
hi Micha, Octane's edge rounding is via a shader created at runtime. But for this to work, it requires the vertices of the geometric objects to be welded before applying the round edge value.
i72630QM @ 2.00GHz | 6GB RAM | 2GB GeForce GT 540M | Win7 64bit
So, please try to add this feature for Rhino too. There is a note that the Rhino soft edge feature needs to be used, but it's not so stable working.
http://www.simulacrum.de - Visualization for Designer and Architects
Win7 64 | Dual Xeon E5-2687W | 32GB RAM | 2 GTX 780 6GB | Rhino3D
Rhino does not provide meshes with merged vertices, so the Octane round edges feature does not work. Instead, use the Rhino round edge feature.So, please try to add this feature for Rhino too. There is a note that the Rhino soft edge feature needs to be used, but it's not so stable working.
I use a third party software for unfolding UV and this one needs welded edges. During export from Rhino I need to enable vertex welding "welded". For example this cause that I can export a complete welded (closed) mesh cube, but the edges are still sharp (not smoothed displayed). So, maybe you need to enable something for the export to Octane too.
The Octane plugin doesn't "export" the scene - it gets the raw geometry data directly from the Rhino API - so that is not an option - sorry.So, maybe you need to enable something for the export to Octane too.
Sounds like the McNeel team could help, since the functionality is there available. Or doe's the welded export to the standalone not work?
You are far better off using the Rhino round edges, since at the moment they work much better than the Octane round edges.
