Issue with Alpha Channel
Ron
Have a strange issue when using alpha channel in conjunction with emmisive material. The red beams use emmissive material to fake laser light.
Don't understand why the red beams ar cut whenever no other object is beyond them.
Can someone help?
Thanks - Ron
With Alpha
With Alpha
Without Alpha
Without Alpha
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
Ron
No one having some tipps for this one?
chupinsky27
Ron wrote:No one having some tipps for this one?
Not sure if this relates to your issue but I was having problems with my alpha channel too...
viewtopic.php?f=30&t=49647
-Craig
C4D R17 | c4doctane v3 beta 2.1 | 2x980ti 2x780ti watercooled | Windows10 | 64GB ram
Ron
Thank you Craig!
This helped.
I had noticed this thread before but did not look close enough into it. The solution is to use 32bit EXR with settings described.
Ron
chupinsky27
Ron wrote:Thank you Craig!
This helped.
Ron
I'm glad that solution worked for you as well.
-Craig
