LiveDB not working?
megacal
I installed the latest OctaneRender for Blender/Octane Server combo, and everything is working,
except when I create a new window, and select Materials LiveDB at the top of the popup list,
the LiveDB doesn't show up. (?)
I have internet access, and am rendering an animation no problem, but would like to use the
LiveDB mats.
2 GPUs: Zotac GTX 580 1.5gb Amp! GPU for Octane....Galaxy 210 1gb for display
CPU: AMD Phenom II X4 955,3.2 ghz RAM: 8gb OS: Win7 64
JimStar
Works OK for me.
Do you run the OctaneServer on the same computer where the Blender is run? If not - set the correct IP address (you can see it at the bottom of Material DB view).
megacal
Hi JimStar,
OR4B & Octane Server are on the same computer.
I didn't use the default install, but run them from an external HD,
but always worked fine, including LiveDB.
The server address is the same as the address in the MaterialsDB window.
megacal
It's working fine now......and I don't know why. :lol:
Thanks for everything. :)
Return to “Blender”
