problems with instances
gigi
I have a problem with a scene. when loading instances Octane crashes is this message "FAILURE RENDER: the rendering can not be completed. Enable and check the log file for more details. What do you think?
Pc laptop | Corei7 at 2.8GHz | 16GB | GeForce GTX 980M 8 GB | 240 GB SSD | 500 GB 7200 Rpm| Windows 8.1 pro 64 |
gigi
I understand the problem. the istance contained the displace and I assume this is the reason of the crash. eliminating displace the problem disappeared.
juanjgon
Yes, this message means a fatal error in the Octane render core. If you have a lot of objects with displacement, the render can fail.
Return to “Lightwave 3D”
