As many of us, I'm a Visualize user.
Is there a way to render the 'hair system' coming within the Visualize?
Thank you
L.
Grass, grass, grass...
what you did is c4d grass which is not supported by octane
you can use hair or displacement(I suggest)
Thank you. I knew that... Only was hoping that Ahmet the magician...enigmasi wrote:what you did is c4d grass which is not supported by octane
L.
PS The problem, using displacement, i that the blades are straight... Maybe you know some tip and tricks...
Mac Pro 5.1 -16 GB- 2 x Titan Black 6GB - Titan Z - MacOS Yosemite 10.10.4
You could also do two render passes: Render your scene in Octane without the grass, then render a version of just the grass using the grass shader. Then composite the two.
Download my free Octane resources!
Paper Lantern | Fresh Snow (C4D Only) | Keyboard Displacement Texture | Solar Panel Texture
Mac Pro (2012) | 2x6Core 3.06GHz | 64GB | 1 x Titan Black 6GB
Portfolio: http://www.deltawavefx.com
I have no time to work on. But definitely i'll check in future.
