Folks,
I was trying the Skyler Character from Daz and found some odd output in Octane;
http://www.daz3d.com/skyler-character-a ... 2-female-s
First, it has spectacular, SSS maps, and diffuse only. The auto transfer to the plugin put the diffuse into Bump and Displacement, but frankly, they seem to be inverted. The eyebrows go in the surface, not out. Flipping Invert for the textures does nothing meaningful. I tried defining it as color ad grey images as well.
Is there something I'm missing about Invert? I assumed it would do the opposite, and in particular for bump/displacement maps, what ever the source..
On a lark I created normals, only I got weird seams all over the place. (Click! I have both G3F and G2F versions, so I may have created the normals for the wrong skin... lemme check.)
Daz Skyler Character.. no bumps or normals.
Moderator: BK
- larsmidnatt
I don't think you are missing anything regarding invert. have you tried using just bump or just displacement to make sure they aren't competing?
Win10 x64
i9 10900k 64GB
2080S 8GB
DS 4.15 OcDS Prime ^_^
i9 10900k 64GB
2080S 8GB
Yes... I did both, and tried invert on each one. I also did that with both enabled. Lots 'o combinations, no effect. Both removed is smooth.larsmidnatt wrote:I don't think you are missing anything regarding invert. have you tried using just bump or just displacement to make sure they aren't competing?
The thing I notice is that for instance if I change displacement strength it re-triggers a render, right? Press "invert", and nothing happens.
I also get that there may be something wrong here. It is a color texture being dumped into what is effectively a grey Image slot. I have noticed that there is an invert shader thingy, so maybe I should actually use that.
Intel i7-4790K, Asus Z97-A, Corsair 32GB DDR3 1866MHz CL9, 2XAsus STRIX GTX980 DirectCU II OC 4GB, 4XSamsung 840 EVO Raid 10, Win 7 x64 Pro.
I just tried it all again and confirmed it. I can't seem to get this to work. Bumps come out inverted, and I can't do anything about it.
If I use normal maps generated from the skins I get more than seams as well. I get linear distortions. Its not subD, or smoothing.
- larsmidnatt
normally invert works fine for me, but I'll admit I dont know I've ever used it for bump. I know I've used it for diffuse, and for grey image maps used for mixing two materials. So invert does work, but maybe there is a particular bug regarding invert and bump maps.
Win10 x64
i9 10900k 64GB
2080S 8GB
i9 10900k 64GB
2080S 8GB
Yeah. Hey. I could convert the image to B/W and see if that works.larsmidnatt wrote:normally invert works fine for me, but I'll admit I dont know I've ever used it for bump. I know I've used it for diffuse, and for grey image maps used for mixing two materials. So invert does work, but maybe there is a particular bug regarding invert and bump maps.
