Siding
Autodesk Revit (Integrated Plugin developed by Paul Kinnane)
geofnarlee
Thought this could be made with "checks" texture but don't see how to make the shadow lines thin and the (say) clapboard wide...
Hi - can you post a screenshot of what you are trying to achieve pls?
geofnarlee
anything like this, Paul.
THX,
Geof
Thanks Geof. I'm still not sure what you are trying to achieve.
geofnarlee
That is clapboard siding on a house. I made that in Revit, in the Appearance Tab, using the Tiles procedural. I was hoping Octane had an analogue to that.
You can use the texturemap you created above in an Image node in the diffuse pin of the Octane siding material.
geofnarlee
Thanks, Paul. I just thought there might be a "procedural" way, which gives a quicker ability to modify. But no problem/that works.
Return to “Autodesk Revit”
