Crash on changing current frame
johnhorizonvp
Hey there,
I am using Lightwave 2015.2, and tried with the current stable build as well as the latest untested plugin.
Both crash as soon as I try to change what frame I am on in the timeline while IPR is active.
I've tried updating my CUDA driver, and downgrading it, with the same problem.
Any ideas?
-John
johnhorizonvp
Seems to be fixed by checking "IPR stop using kernel samples" in the options
juanjgon
Weird issue. Can you send the scene to me to test it here? ... it is hard to say what could be the problem without more information.
If you can't send the scene, please enable the log file in the plugin render options to know where the plugin is crashing.
Can you test if the IPR also crash in "Full. Upd" mode?
johnhorizonvp
Seems to happen more when camera is selected and timeline frame is changed.
Attached is a basic scene - just a sphere and found plane. It still is crashing. Note:
There are no nodal render target assigned (if that matters).
TestScene.zip
(360.55 KiB) Downloaded 171 times
juanjgon
Are you working on OSX? ... I have seen problems with the plugin in OSX 10.10, but I can't reproduce them here. I will test your scene anyway.
What version of the plugin and OSX do you have?
johnhorizonvp
OSX: 10.9.5 (current Mavericks)
Plugin: LWOctane 2015.1.plugin (Jun 5, 2015)
juanjgon
Here I can't reproduce the problem. Can you please test this new build to see how it works in your system?
https://www.dropbox.com/s/prod4ddv271a4 ... n.zip?dl=0
You should see in the about box that it is the version 2.23.2.2 (Jul 7 2015)
I have other Mac user also with crash problems in the IPR and he also has Quadro GPUs ... I am not sure if it could be a drivers problem.
johnhorizonvp
I will try that. Thank you for your quick attention to this! :)
johnhorizonvp
Nope - still crashes. Did seem a little better, though. If I rotate the camera back and forth very quickly with IPR open,
that's when it crashes. Some sort of update issue I guess. Also, I noticed that the depth-of-field seems to be out of scale.
Not sure if it is related, but objects at real-life scale appear to look very small due to the shallow depth-of-field, as if
they are tiny. Possibly a scale issue?
juanjgon
What CUDA driver version do you have in your system?
Return to “Lightwave 3D”
