OctaneRender 2.2 for LightWave Production build 2.25
Forums: OctaneRender 2.2 for LightWave Production build 2.25
Re: OctaneRender™ 2.2 for LightWave™ - Production release
Postby MrFurious » Thu Jun 25, 2015 2:38 am
MrFurious Thu Jun 25, 2015 2:38 am
Thanks J works a treat so far.. Render layers rock! Maybe used with alpha output I can finally setup object masks as I've always wanted to. Maybe we''l have the same for materials one day?
Dino Inglese
CG Artist
Melbourne Australia
Intel Core i7-4820K, 3x GTX 980ti
Windows 7 64bit, Modo 12.2v2 for PC
Octane build 4.04.0.145
MrFurious
Postby MrFurious » Thu Jun 25, 2015 3:22 am
MrFurious Thu Jun 25, 2015 3:22 am
Render Layers w/ Render Layer Mask is it!,. Juanjo this is awesome. Plz plz surface as well as objects for layer masks
Dino Inglese
CG Artist
Melbourne Australia
MrFurious
Postby MrFurious » Mon Jun 29, 2015 9:36 pm
MrFurious Mon Jun 29, 2015 9:36 pm
Juano having some issues with the latest plugin release 2.23.2.1, where IPR picking surfaces and editing them means I have to reload IPR to see the changes. Also other oddities where IPR selecting a surface will mix up other surfaces in the scene. I remember something similar going on with a much earlier build (1.5x something) but was then fixed.
Dino Inglese
CG Artist
Melbourne Australia
MrFurious
Postby juanjgon » Mon Jun 29, 2015 9:41 pm
juanjgon Mon Jun 29, 2015 9:41 pm
MrFurious wrote:Juano having some issues with the latest plugin release 2.23.2.1, where IPR picking surfaces and editing them means I have to reload IPR to see the changes. Also other oddities where IPR selecting a surface will mix up other surfaces in the scene. I remember something similar going on with a much earlier build (1.5x something) but was then fixed.
Weird issue. I don't have reports about problems with the IPR picking in the last builds. Do you have a sample scene to reproduce this problems?
juanjgon
Postby MrFurious » Mon Jun 29, 2015 9:54 pm
MrFurious Mon Jun 29, 2015 9:54 pm
Impossible to send you the file I'm working on now but will try and get a test scene to you asap. Perhaps it's because I'm using the 2015.2 plugin version inside of LW 2015.1?
Dino Inglese
CG Artist
Melbourne Australia
MrFurious
Postby juanjgon » Mon Jun 29, 2015 10:16 pm
juanjgon Mon Jun 29, 2015 10:16 pm
MrFurious wrote:Impossible to send you the file I'm working on now but will try and get a test scene to you asap. Perhaps it's because I'm using the 2015.2 plugin version inside of LW 2015.1?
Thanks. I don't think so, but anyway perhaps you could install the 2015.2 release only to test your scene with Octane. In theory the 2015.2 plugin should work in 2015.1 without problems.
juanjgon
Postby MrFurious » Mon Jun 29, 2015 10:24 pm
MrFurious Mon Jun 29, 2015 10:24 pm
juanjgon wrote:...perhaps you could install the 2015.2 release only to test your scene with Octane...
Not an option right now unfortunately.
Dino Inglese
CG Artist
Melbourne Australia
MrFurious
Postby atnreg » Tue Jun 30, 2015 5:46 am
atnreg Tue Jun 30, 2015 5:46 am
I happen to still have 2015.1 installed as well (lazy me :D).
So I tried the 2.23.2.1 in it and it picks the surfaces from IPR without problems :)
So your problem must be somewhere else or then something specific with surfaces. Can you tell me what kind of surfaces you have problems with so I could make similar here and test? Or even send the SRF files + needed textures by PM?
Good luck :)
Antti
AMD Ryzen Threadripper 2990wx (32c/64t),64GB RAM,NVIDIA GTX 1080ti,Win10
Clarisse 4,Houdini 18 (+Octane 2019),Blender2.81,Fusion360,Onyx,ZBrush,SubstPnt...
Started: Houdini 2019, Clarisse 2016
No business, just fun :)
atnreg
Postby gordonrobb » Tue Jun 30, 2015 8:45 am
gordonrobb Tue Jun 30, 2015 8:45 am
Just been doing some texturing using Presets. Would it be possible to implement drag and drop between the presets panel and the IPR window? That'd be cool.
gordonrobb
Postby juanjgon » Tue Jun 30, 2015 8:53 am
juanjgon Tue Jun 30, 2015 8:53 am
gordonrobb wrote:Just been doing some texturing using Presets. Would it be possible to implement drag and drop between the presets panel and the IPR window? That'd be cool.
Sorry, the LightWave SDK doesn't support drag and drop features at all.
juanjgon
PreviousNext
Return to Releases
Wed Jun 05, 2024 1:41 pm [ UTC ]
