Render region?
Moderator: JimStar
Joss
Quick question: does plugin in it's current state supporting region render from command-line?
I have resolutions up to 4500 where just part of the frame is occupied, so to save time and memory it would be smart to render just part of the frame, but i don't see standard "-reg" option in "render -r octane --help" output.
PS: Previously there was a "documentation" button on the Octane shelf, now it's gone, where's the maya plugin documentation resides in the filesystem, anyone?
Thanks.
Freelance CG TD, developer.
abreukers
hi, the documentation can now be found at the Octane Universe. you can chose to download it through "Product Manuals" section if you want to have a local copy on your machine, please check from time to time as there might be some newer entries to it.
by the way, Octane doesn't do region render via the command line, I guess this is why there is no option for it. cheers
i72630QM @ 2.00GHz | 6GB RAM | 2GB GeForce GT 540M | Win7 64bit
Joss
Thank you for answers.
Return to “Autodesk Maya”
