Thank you all .
I need to address an issue about the script that I found out lately.
If you change the HDRI environment manually. Say:
- Change the Translation of the HDRI ( rotate the hdri by hand)
- Change the HDRI image manually.
If the script is running already. It cannot update the hdri rotation. To solve that issue
Please close and reopen the script. Currently the script initialises and refreshes the values at script opening.
I will either put an update button there.
Or will find a way to read the changes in hdri interactively.
But I guess there are some integration problems with the max plugin vs. maxscript.
Please bear these in mind.
Octane Shortcuts v3.1 (updated)
My Portfolio
updated v3.2 of my script
With this version you can create a target IES light with a single click.
Due to limitations with the maxscript connectivity. To enable the target option with the ies light,
An initial IES light file has to be loaded to make it work.
So I supplied a basic ies light that I use often. 08.ies
You'll have to copy that to your root folder of C drive.
Secondly, now you can create a Octane Camera from the current viewport perspective with a single click.
Download from the first post
Enjoy!
Enjoy!
My Portfolio
Yes I do.Goldisart wrote:do you have the same HDRI maps but in HI resolution ?
https://yadi.sk/i/uahbrRPAhRx3q
My Portfolio
if I can help and take a photo HDRI 360 your light box....
http://www.goldis-art.com/#!-/ciif
..... I understand that you will later spread to the General work or it will be paid using
I would like to get HI resolution HDRI maps
I have no intention to sell this script.Goldisart wrote:if I can help and take a photo HDRI 360 your light box....
Those hdri are free I found on net. I use different hdri for my own work. The hdris I included are downscaled versions of it.
You can updade the supplied hdri's and material library to use it with your own textures
My Portfolio
Great free high-res hdri's (15k):
http://noemotionhdrs.net/hdrevening.html
Octane for 3ds Max v2.21.1 | i7-5930K | 32GB | 1 x GTX Titan Z + 2 x GTX 980 Ti
Mate there are tons of free hires hdri's on the net.Goldisart wrote:good HDRI but I would like to get Hdri maps script
Search and you'll find. It is not a good thing to share that aren't mine.
So I scaled them all down and blurred them. They are a bit not useable I know.
But I had to put those just to make you guys understand how it works.
Think of them as a placeholder.
The script lets you change all of the HDRis with your own most used hdri's. They are not hard coded.
Change the matlib I supplied with your own hires HDRi's.
The names of the hdri's comes from material library.
You can also add more and more hdris a well.
My Portfolio
