Animated texture problem.
roger1972
I'm trying to animate a water surface. In IPR window it's working as long as I have the material node window open. If I close the Material Node window the texture will not animate. If I press F10 the same problem.
posted my setup...
3 x RTX 3090 / 1 RTX 4090
96 GB RAM
Threadripper
roger1972
problem solved... Mat Upd :-)
96 GB RAM
Threadripper
scaphoide
hi, i try to animate water too but imposible. Nothing move. Is it possible to have the preset file ?
Thanks.
juanjgon
As roger1972 has said, usually if an animated material is not updated the problem is that the update materials option is disabled in the render target root node options panel or in the IPR (the Mat.Upd button)
Return to “Lightwave 3D”
