ViruValge Bottle
ramone163
Second try to render bottle with Octane. Same mistake, need to rerender with PT. Also love Octane displacement map - very fast.
GPU: 2x4090; 3ds max;
Behance portfolio; Handmadefont.com;
itsallgoode9
did you have any issues with the label and geometry intersecting, causing faces to disappear, when using displacement? I seem to randomly run into that issue on my labels and can't figure out exactly what is going on. Last label I did, I had to offset it off the glass more than a millimeter before it would render correctly, so I ended up having to render the label in a separate pass, which i was trying not to do.
