render failure error message.
xcaseyx
So the render goes along fine, its not a complex or big scene at all, but this error keeps happening.
CUDA error 702 on device 1: The device kernel took too long to execute. This can only occur if timeouts are enabled. The context cannot be used anymore and must be destroyed. All existing device memory allocations from this context are invalid and must be reconstructed.
    -> could not get memory info
any idea what I should do?
in theory, you should be able to fix this using one of the latest Standalone installer:
http://render.otoy.com/customerdownload ... _win64.exe
Let us know if this solve your issue ;)
ciao beppe
xcaseyx
Hmmm I've already upgraded. I'm on 2.23.2rc4 and latest standalone.
ok,but you have used the standalone installer? It set some registry in windows for solving the timeout. If yes, try to search in the forum for displacement timeout, you should find the answer :roll:
ciao beppe
