Render animation issue?
juhatakabe
aoktar wrote:
juhatakabe wrote:
aoktar wrote:I think there is something which is incompatible. Maybe some tags,materials,etc.. from a different renderer or so.. Best method to disable some objects and try to render.
Thanks for your tip! I deleted all materials and sure it rendered just fine so now I have to narrow down which material is causing error.
Thanks again, now I can continue!
Can you let me know your findings? I may fix it.
I had some C4D standard materials and not all was Octane specific materials. I used convert materials and almost all converted just fine except those with Layer shader on diffuse. I hope it will help you. At least my scene is rendering just fine now! Thanks
Houdini 21
Win / RTX4090
Mac / M4 Max
