OcDS Setup v2.2 (last Beta)
Moderator: BK
larsmidnatt
Protip: if you notice anything weird with the plugin, save a new copy of the file and close daz and reload everything. This helps with old files you may be opening for the first time in the new plugin, as well as if you do something crazy like below.
Proof that there is some success with geografts now. I notice some quirks, but I think its usable now...I expected this extreme example to fail actually. 3 geografts at once...
UPDATE: Tested both Genesis and Genesis 2 female. Both my catgirls now work! I suggest you create the figure with geografts. Save, close. Reopen then create materials for the best success.
I'm not done testing, but thanks t_3, this update seems solid so far.
Win10 x64
i9 10900k 64GB
2080S 8GB
DS 4.15 OcDS Prime ^_^
thongology
Anyone else having trouble typing exact values into the NGE? Or the LDB when searching for a material? More often than not I am unable to type exact values; only the sliders work.
EVGA Z97 Classified| 4790K @ 4.7 ghz| 32GB RAM | 2 x Titan X | Windows 8.1 Pro | GeForce Driver 365.19
swipswap
This release is making squeaky wheels like myself shut up. Very solid and professional plugin. Finally being able to ditch 4.7 is a huge relief. Looking forward to hearing about the roadmap.
Only issue I've had so far is the viewport resizing when you show/hide the side tabs, especially annoying if you have the viewport maximized on another monitor. Seems like an obvious bug that t_3 is probably already aware of but I submitted a report anyway.
If anyone is having an issue not being able to upgrade the plugin from v2.1 to v2.2 like I did, deleting plordazs.dll from C:\Program Files\DAZ 3D\DAZStudio4\plugins\OctaneRender prior to upgrading did the trick for me.
thongology wrote:Anyone else having trouble typing exact values into the NGE? Or the LDB when searching for a material? More often than not I am unable to type exact values; only the sliders work.
How precise are you trying to be? The manual doesn't say how precise float values are but the standalone interface shows 7 digit precision (1000.000). Haven't had an issue yet with typing in values or filtering the Live DB.
roeland [url]http://render.otoy.com/forum/viewtopic.php?f=73&t=42750&p=214585#p214585[/url] wrote:The scale value on the X and Z axes don't matter much as long as it's larger than your scene. On the Y axis it can't be too large, since floating point calculations only have about 7 digits of precision.
Veneris
The animation works wonderfully, T_3 I invite you to eat some Tacos. Here in México.
Intel Core i5-2500 CPU @ 3.30Ghz (Quad Core), 12.0GB RAM, NVIDIA GeForce GT 620. Windows 7 (64 bits)
birdovous
I would say that this release was timed very well as today I should receive a package containing two new Titan X cards to replace my old Titan and 780 Ti. So I'm really looking forward to give the new plugin a spin and burn in those Titans! :D
btw what is the recommended DAZ version for the 2.2? Should I use it with the 4.7 I use now for the v1.2 of the plugin or should I go with DAZ 4.8?
Birdovous
Master: Core i7 2600K, 32GB RAM, 2x EVGA GTX Titan X (SC)
Slave 1: Core i5 4460, 16GB RAM, 2x EVGA GTX 1080 Ti SC2
Slave 2: Core i7 9700K, 64GB RAM, 2x ASUS RTX 2080 Ti
TRRazor
Thanks for the update t_3 - looks nice so far and seems to run very stable.
Good work!
PS: Seems to run well in DS 4.8
W10 64 bit | i7 3770K | MSI Geforce RTX 2080 (8GB) + GTX Titan Black (6GB) | 32 GB DDR3 RAM
Laticis
Thank you very much t_3 :)
voto1979
I really like the overall look and how you structure the plugin ... its very accessable (even better as the standalone version but I guess it's personal preference)
Everything's in place clean an quick to access. The only thing is that we could dock the render viewport in application itself.
However I am very happy with the UI.
voto.1979
Windows 8.1 / Octane Standalone Application / GTX Titan Black 6GB + GTX 970 / Intel Core i7-4930K CPU @ 3.40GHZ (6 Core / 12 Threads) / LG 34UC87
asennov
Thanks for update, shall test it this evening.
(Ho-ho, spells still work :) )
Win 7SP1 64bit | i7 3770 | 32Gb RAM | 2x780GTX
t_3
what happens? does the input field go out of focus, so that the value is reverted?
this could happen when the mouse is moved away, and another ui-element captures the mouse focus - this would trigger esc/input-undo on the last active input field.
i was able to force such a behavior by moving the mouse around a bit (after clicking into an input field), and at some point it went inactive - what it actually shouldn't do. if it's that, there should be a fix - once i found out what other element(s) may steal mouse focus but should not.
„The obvious is that which is never seen until someone expresses it simply ‟
Return to “DAZ Studio”
