cached dynamics - not all instances rendered (SOLVED)
mrom
I have a cached emitter with an octane object tag. renders fine in LV, somehow stops the emission in the final render (and shows some dots instead of coins).
Why could this be? Running 2.23.1 RC4, re-cached, restarted, nothing changed.
How is the idea to put a scene for checking?
Yambo
Under Octane render settings "Send all scene's data" is checked? instead "resend only update objects"
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0 :)
https://yambo.me
mrom
Sadly, yes.
mrom
aoktar wrote:How is the idea to put a scene for checking?
the coins' textures are from pixel lab, I am not sure if he would approve :)
changed the coins to primitives, problem stays. scene attached.
I have to say, that the support in this forum is the fastest thing I have ever seen - just brilliant! Thank you all!
jar_collected_nocoin.rar
(731.37 KiB) Downloaded 226 times
You're welcome. It looks like a user bug;)
1-Birthrate renderer=20, try it as same on Editor's
2-Disable particle engine to avoid small spheres
mrom
Oh damn, I am not a clever man and feel deeply ashamed. I blame x-particles for not using the emitter in 2 years and overlooking the quite obvious.
Thank you! Aargh :)
mrom wrote:Oh damn, I am not a clever man and feel deeply ashamed. I blame x-particles for not using the emitter in 2 years and overlooking the quite obvious.
Thank you! Aargh :)
Np. It's usual while working. But people should be sure that I'm trusting to my work for stability.
