It's possible to render with the cpu ?
it's because my scene is very very big and i have a lot of textures with maps in minimun 4K so the vram of my 2x Titan black can't calculate that scene.
Thank you
render with cpu
no it's not possible to render on CPUs, but.. if You use latest Octane (not like a demo or such), simply enable out-of-the-core (just go to file>preferences & there You'll find a tab "out of core" textues) & those will get off-loaded to system ram instead of vRAM on Your GPU card. If textures is all that causing Your scene from renderign out =) You should be able to solve & render out result =)
drop a line if You need any more help =)
- guigui441987
ok i find the option "out of core"
but how it's works, because when i turn on the option, i see nothing in my prewiew window.
i see 0mb/4gb by default
- philliplakis
glimpse wrote: (just go to file>preferences & there You'll find a tab "out of core" textues)
Hey glimpse
I can't find the tab I'm running 2.17
*** Found upgraded to 2.23.2 ***
Win10 - 6700k - 32gb Ram - GTX Titan X (Pascal) + GTX 1080
