EK waterblock but bear mind that you need 3-4 exactly the same gpus to watercool them at once.
http://www.amazon.com/EVGA-GeForce-384- ... tx+780+6gb
Video card advice
- jscottsmith
I have two of those cards already in my current machine. Are you talking about buying them used?
(2) Geforce GTX780-6GB | i7 5820/6800 | 32GB
Win 10-64 | Octane v3.05.3 | NVidia v381.65
Scott Smith
J. Scott Smith Visual Designs, Inc
https://jscottsmith.com/
Scott Smith
If this is not a problem for you...
- jscottsmith
That's fine. I was wondering if you knew of a new source for them.
So, about watercooling... I've never installed any. My computer has a few self-contained WC components, but that's it. How would I go about learning all the parts I need and how to set them up?
Lastly, on my current system, I have (2) 780s and a 650. I use the 650 for displays, and the 780s for render. Would it make sense to replace the 650 with a 780 so I could WC them all, using one of them for display?
Scott Smith
Scott Smith
Yes - go with 4x780 6gb. For WC advice read my build log. The rest is on youtube and overclock forum.
- jscottsmith
Ok, reviewing your list from earlier...
In the first three lines, it looks to be about $700. Does that sound right? I'm not sure what the rest of the items are in order to look them up. Here's what I have so far. Am I close?
http://www.amazon.com/EK-XRES-incl-Perf ... 391&sr=1-1
http://www.amazon.com/EK-MultiOption-RE ... 37&sr=1-28
http://www.amazon.com/EK-CoolStream-Rad ... 0+radiator
Really... 20 fans?2x D5 PWM pumps with tops
1x reservoir
2x480 radiators
20 120mm fans
fittings
tubing
temp sensor
controller
waterblocks and backplates
Scott Smith
Scott Smith
- adriendupagne
Hi guys. I have 3x titans and 1x titan X.
I am getting 90 degree temps for my titans whilst using octane...is this safe? I am using CPUID HW monitor.
safe anough, but get better fans if noise isn't a problem, tune a lot of airflow through Your case. if that is not going to help, manually set lower temperature target & it should be fine =) but You start loosing render performance. Watercooling is another option..
- adriendupagne
Higlimpse wrote:safe anough, but get better fans if noise isn't a problem, tune a lot of airflow through Your case. if that is not going to help, manually set lower temperature target & it should be fine =) but You start loosing render performance. Watercooling is another option..
Thanks for replying
Ok. So 90 should be ok temps. Performance at the moment is great so I dont want to touch the gpu settings etc.
They make a fair bit of noise but I really dont care. Noise isolating headphones covers that.
I will look into getting some more fans to put inside my case. I have 750D Corsair Case. Can you recommend me any decent fans?
This may help
