OctaneBench
Forums: OctaneBench
Re: OctaneBench
Postby Tutor » Fri May 22, 2015 5:43 pm
Tutor Fri May 22, 2015 5:43 pm
smicha wrote:
Tutor wrote:It's two, two, two tools in one: an excellent benchmarking tool and an excellent assist tool for goal oriented GPU tweaking. Just as the best tool to assist in tweaking CPUs to handle Cinema4d CPU rendering speedily is Cinebench, the best tool to assist in tweaking GPUs to handle Octane GPU rendering speedily is now OctaneBench. Octanebench will help my system to peak again further to the right and simultaneously help me to establish overclock presets for various rendering tasks. Compare this - live in development - [ https://render.otoy.com/octanebench/sum ... GTX+780+Ti ] with Score Distribution pic, below - first large hump is where my system's performance had stalled before I had realized that there could be other uses to OctaneBench; lower humps to right is where OctaneBench's assistance came into play during tweaking of this air-cooled GPU system. Now, my ultimate goal is to get an OctaneBench score of, at least, 960 (or about 120 pts per 780 Ti ACX SC OC) on this system, while keeping all GPU temperatures below 85 degrees (C); my interim goal is to get a score of, at least, 912 (or about 114 per GPU).
Tutor,
The results you've posted are indeed impressive, especially these are air-cooled cards. According my calculations 8x780Ti may score around 1060 (watercooled) on stock bios. My GTX 780 6GB which has 2304 cores - scores 106 (1340 Mhz on core and 7000 MHz on memory). Hence a 780 Ti with 2880 cores has 25% more of computing power giving 1.25*106=132.5. Such results require overclock over 1300mhz and I am not sure how well the stock fan would cope up with heat dissipation. Hope to see you breaking 1000 score limit. Good luck ;)
BTW I managed to get 0.044375 score per core on a 9600 cored system (0.046 for a single 780).
Thanks for the 780 TI projection and other information. Like minds often think alike and sometimes nearly simultaneously. Guess what my project for this weekend involves? Lets just say it involves a significant no. of GTX 780 TI ACX OC SCs and H20. I'm also thinking outside of the box - literally, because there'll so many of 780s that the box can't contain them even if I wanted the security of the inner womb of the case.
At least one observation that I've made from studying the various OctaneBench scores, is that, although Octane scales linearly for each additional, identical GPU card, the real world performance addition for each additional, identical card seems to be less and less than what I would have expected. Try it with the scores for the Titan Xs by looking at the performance for single card systems; then compare with that of dual Titan X systems, etc. on to four or five Titan X card systems. Interesting what each addition of an accelerator does, especially when it also adds more heat and/or act to block maximal air flow for its neighbor.
Because I have 180+ GPU processers in 16 tweaked/multiOS systems - Character limit prevents detailed stats.
Tutor
Location: Suburb of Birmingham, AL - Home of the Birmingham Civil Rights Institute
Re: OctaneBench
Postby Tutor » Fri May 22, 2015 5:59 pm
Tutor Fri May 22, 2015 5:59 pm
glimpse wrote:
Mannimedia wrote:..
Quad GeForce GTX TITAN X
Total score
574.916206
Nice score! on air or under water? =)
I'd be stunned if they aren't underwater. 574.916206 / 4 = 143.729.
Tutor
Re: OctaneBench
Postby sadece » Sat May 23, 2015 12:04 am
sadece Sat May 23, 2015 12:04 am
Looking forward to see 980 Ti score :o
http://www.sadece.com.tr
i7 990x // 12GB Ram // 2x Titan X + Titan + 780 // Octane for C4D // Win7 x64
sadece
Re: OctaneBench
Postby glimpse » Sat May 23, 2015 9:52 am
glimpse Sat May 23, 2015 9:52 am
Nice score! on air or under water? =)[/quote]
I'd be stunned if they aren't underwater. 574.916206 / 4 = 143.729.[/quote]
setting fans 100% a friend of mine got a lot of noice but under the load GPU sits less than 60C =)
so I wouldn't be too surprised to see that on air =).. with enough of case airflow..
glimpse
Re: OctaneBench
Postby smicha » Sat May 23, 2015 10:05 am
smicha Sat May 23, 2015 10:05 am
BTW Two days ago I saw a youtube video on evga 980 clocked to 1620mhz at 1.25V on a hybrid cooler.
https://www.youtube.com/watch?v=9IkKMc0jVdo
at 4:22
smicha
Re: OctaneBench
Postby Tutor » Sat May 23, 2015 3:35 pm
Tutor Sat May 23, 2015 3:35 pm
smicha wrote:BTW Two days ago I saw a youtube video on evga 980 clocked to 1620mhz at 1.25V on a hybrid cooler.
at 4:22
Might this be one of the partner GPU cooler options on the 2816 CUDA core GTX 980 TIs being released within the next couple of weeks [ http://videocardz.com/55566/nvidia-gefo ... benchmarks ]? I'd like that hybrid cooler on my 980 TIs. Also, I hope that the GTX 980 TI will be boost clocked out-of-the-box significantly higher than the 1215 MHz boost for the GXT 980, making the 980 TI the comparable 3d render speed place holder for Maxwell that the GTX 780 TI is for Kepler.
Tutor
Re: OctaneBench
Postby Tutor » Sat May 23, 2015 3:54 pm
Tutor Sat May 23, 2015 3:54 pm
sadece wrote:Looking forward to see 980 Ti score :o
You will not have to wait long [ http://wccftech.com/nvidia-gtx-980-ti-specs-benchmarks/ ].
Tutor
Re: OctaneBench - upload results not working
Postby ArchPrime » Sun Nov 29, 2015 5:23 am
ArchPrime Sun Nov 29, 2015 5:23 am
I seem to be able to benchmark ok, but the benchmark tool upload button is always greyed out for me . Why would that be?
Octane Render for ArchiCAD 22 plugin v4.x | Octane Standalone 4.x
( 2x Nvidia 980 Ti) x 6MB VRAM | Intel I7 4470K | 32GB RAM | Windows 10
ArchPrime
Re: OctaneBench
Postby glimpse » Sun Nov 29, 2015 7:32 am
glimpse Sun Nov 29, 2015 7:32 am
Tutor wrote:
glimpse wrote:
Mannimedia wrote:..
Total score
574.916206
I wouldn't..if they have sort of hybrid cooler - Think EVGA has TitanX hybrid =) interesting to see nvidia finally allowing to release those =)
Yesterday I pushed 780 6gb from 83 to 99,9 on OctaneBench with simple bump in core speed - render temps under full load stays under 50C (MSI non ref cooler with pair of fans in open air pluged via Amfeltec splitter =)
so pushing TItanX from ~130 to 144 deosn't seem to be a big deal.. =)
glimpse
Re: OctaneBench
Postby LucasRAPP » Sun Jul 31, 2016 3:33 pm
LucasRAPP Sun Jul 31, 2016 3:33 pm
Hello everyone, I have a Quadro and Tesla, for the NVIDIA Maximus system, but at the bench, there is that Tesla is recognized, why? is how to enable Quadro
LucasRAPP
PreviousNext
Users browsing this forum: No registered users and 47 guests
Fri Apr 26, 2024 5:17 pm [ UTC ]
