Request: Side by side inverted stereo output
frifer
Hello!
would be great to have an additional stereo output. Like parallel, but with the images inverted. That allows for crosseyed previewing without the need of any additional equipment.
https://www.lhup.edu/~dsimanek/3d/stereo/3dgallery.htm
woudl be great imho... Youd just have to take the parallel output, and swap the images L/R to R/L.
Rikk The Gaijin
+1
manalokos
That could be easily fixed if eye distance would accept negative values...
abstrax
manalokos wrote:That could be easily fixed if eye distance would accept negative values...
We will extend the IPD range.
frifer
i think it would be more user friendly if instead of increasing the range, there would be a "crossed" option, that automatically puts a minus in front of the eye distance value. so eye distance remainst Always positive and if the crossed option is selected the minus is added behind the scenes.. just my 0.02$.. :)
ThetaGraphics
Any updates on this? It appears that the minimum eye distance is still zero?
OctaneRender - DAZ Plugin
Win 10 64-bit | Intel 17-5930K 3.5GHz| RTX 3090 and GTX 1080 | 64GB RAM
cly3d
I also vote for an over/under (also called top/bottom) stereo format.
This makes it easier for Youtube production as well as is a standard of sorts when editing in Premier and After effects.
Regards.
