Poly Hair Feature Issue
- 3dreamstudios
It seems when I am using the Poly Hair Feature on an object the joints of poly chains don't get rendered correctly. Is this a known issue? It happens in the test scenes I'm running through to learn. Would like to use this feature in the future if the joints were fixed.
- 3dreamstudios
- BorisGoreta
- Contact:
All joints in that scene are broken/cracked, not only the ones with high angle.
- BorisGoreta
- Contact:
Fibers generated by FiberFX are also broken.
