OctaneRender™ for Blender 2.23.1 - 8.3 Linux [OBSOLETE]
JimStar
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Added stereo mode for panoramic camera.
  • Added some linux dependencies into installer.
Installation:
- Just run the installer to see its command line keys.;)
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v8.3 Linux (101.0MB autoinstaller file)
For network slave and daemon please download standalone installer here:
http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
grimm
Excellent, thanks JimStar, stereo side-by-side is working great now. :D
kaiwas
Thanks! Nice work
mac3d
Thanks! Thanks! Thanks! ..
My Computer:i7 2,6ghz ram 8gb schede video nvidia 9600tso 512mb gtx560ti 1gb mainboard asus p6t se sistema operativo:Ubuntu 14.10 64 bit
matrix2012
Hi JimStar
I always get this error message in CentOS 7 1503 .
./blender: /lib64/libcrypto.so.1.0.0: version `OPENSSL_1.0.0' not found (required by /usr/local/OctaneBlender/lib/libOpenImageIO.so.1.4) :(
using the command uses the same ERROR message:
ln-s /usr/lib64/libcrypto.so.1.0.1e /usr/lib64/libcrypto.so.1.0.0 :(
How can I create with https://github.com/JimStar/OctaneBlender.git under Centos 7 1503 can I help her with anyone script a manual.
Sorry for my bad english
JimStar
matrix2012
Do you have OpenSSL installed? If not - try:
yum install openssl
matrix2012
Hi JimStar
CentOS 7 1503
Yes openssl-1.0.1e is installed.
How can I fix the problem?
JimStar
Next version HERE.
Return to “Blender”
