Does it work for you in standalone?dawe wrote:also: moblur dont work on displaced geometry. not sur if this is a bug or a limitation though.
OctaneRender® for 3ds max® v2.23.1 - 1.5 [OBSOLETE]
Octane has many devs. And I hope that at least most of 3ds Max users here have noticed that "JimStar" and "Karba" are "slightly" different nicnames.oguzbir wrote:When I said about this in ornatrix forum Marsel K. from Ephere said he contacted octane dev.
I personally - have never had the Ornatrix license, perhaps Karba had it. This is why it's better when the company's authorities take care of all the licensing stuff, not the separate developers... I let them know about it a week ago, after you posted the bugreport.
It seems Forest object not being treated as an moveable proxy when using custom objects . Therefore Limit to visibility, with auto assign to active view (under Camera rollout), does not update in an animation. It only generates forest positions for the first frame.
I have attached a test scene.
Could you check it thanks Jimstar.
- Forest planting to limit vis on.zip
- Forest Test
- (5.56 MiB) Downloaded 305 times
Sorry mate I didn't have any bad feeling about it. Just desperate to solve my issue. Thanks for all you did was necessary. and I wouldnt know if you didnt have a license. And lastly had no intention mixing the nicknames hereJimStar wrote:Octane has many devs. And I hope that at least most of 3ds Max users here have noticed that "JimStar" and "Karba" are "slightly" different nicnames.oguzbir wrote:When I said about this in ornatrix forum Marsel K. from Ephere said he contacted octane dev.
Again thank you very much explaining that. With that settled I think I have to move on solving my issue with a different approach.
Cheers
My Portfolio
I'm having the same issue. with max 2014
Interestingly, I once saw that it worked as it should
Didnt have time try to identify the problem.
My Portfolio
I also want to say that my friend titan Z graphics card.... I have a gtx 780 in my latest release is 1.5 hair and fur work and his work only in render in the viewport are not displayed. There are no errors
yesterday this feature made him lose:).... decided to rearrange Windows
