GPU Cooling.
Remove hard drive from the spot and put 2x120 fans or 2x140 if they fit. Move hard drive to the other side (it you can).
You have my ear... but, why? Is it that simply adding more air flow will clear this up? (To compare I'd been saying blow air into the hot spot.)smicha wrote:Remove hard drive from the spot and put 2x120 fans or 2x140 if they fit. Move hard drive to the other side (it you can).
Intel i7-4790K, Asus Z97-A, Corsair 32GB DDR3 1866MHz CL9, 2XAsus STRIX GTX980 DirectCU II OC 4GB, 4XSamsung 840 EVO Raid 10, Win 7 x64 Pro.
His is what it looks like there;
Remove the plastic brackets, even cut the metal piece and put fans there blowing air onto gpus.
Believe it or not... I've tried everything, and still no improvement in temperatures. I have a lot of fans now.smicha wrote:Yes, it will improve temps. And you don't have to go with high static pressure fans for internal fans. Look rather for something with high airflow. Noctua NFS12 is great and silent, noiseblockers too. Just place one/two fans at a right side of gpus and if possible one in front and bottom.
If you can get 2-4 some fans from a store and ask if you can give them back (just in case if it won't work for you).
If you are looking for silence... watercool'em.
I even put in these to allow more air to go by the GPUs, and they did help a little bit, it seemed to take a lot longer to hit higher temperatures.
Silverstone Aero Slots Vented Slot Covers
http://www.silverstonetek.com/product.php?pid=170
I'm not keen on assembling all separate bits (pumps etc) for water cooling. Are there any aftermarket factory sealed options out there?
I may just give this a shot. I think it will let way more noise out though, but its hard to argue with a big honken fan.glimpse wrote:Another option =) One big fan that blows the air on GPUs =)
https://twitter.com/tomglimps/status/574889522925821952
