Cuda Error - Can't seem to find a solution
kerryoo
I'm getting an error that says the following
CUDA error 1 on device 0: One or more of the parameters passed were not within an acceptable range of values.
-> failed to bind texture to device memory (data5)
device 0: failed to bind data texture 4 of context 0
It just started all of a sudden. I tried to track back and undo any changes I did before it started but nothing seems to work :(
I've uploaded the project temporarily on to my dropbox here https://www.dropbox.com/sh/gge8vkkeltmj ... m5FXa?dl=0 - EDIT (REMOVED)
Any help as soon as possible would be much appreciated as I have deadline with this next week :shock:
Thanks much,
Kerry
do you know the limits of Octane? I think you should decrease polygon counts in your scene
kerryoo
I was not fully aware of this, sorry about that. Thanks for the quick response. I will read up on it now.
Kerry
TonyBoy
Will the latest build (using on board RAM as a backup) eliminate this problem?
TonyBoy wrote:Will the latest build (using on board RAM as a backup) eliminate this problem?
if you are talking about out-of-core, that's just for textures not geometry or render buffers.
TonyBoy
Good to know, thanks! Especially thank you for such rapid developemnt.
TonyBoy wrote:Good to know, thanks! Especially thank you for such rapid developemnt.
It's a pleasure for me to be here. Enjoy it
