1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
- Implemented LiveDB support for the new type of gradient texture.
Installation:
- Just run the installer to see its command line keys.
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &DOWNLOAD
Blender Octane Edition - v7.10 Linux (96.3MB autoinstaller file)
