Animation trouble (SOLVED!)
martincarlson
I'm trying to render an 400 frames animation in Picture Viewer. It renders frame 0, then it stops.
Version 2,22. Cinema R16. Windows 7.
Frame range is set to All Frames. Tried Manual also. Same result.
Save files is checked.
Method: Resend only updated...
Martin Carlson, Visual and Audial Designer at Katzenwaffe Creative Studio | www.katzenwaffe.se | Soundcloud | Twitter
Intel Core i7-5930K / ASUS X99-E WS / 2 x EVGA GeForce GTX TITAN X 12GB / 32 GB RAM / Windows 10 / C4D R16 / Octane Standalone 3.03.3 / OctaneC4D 3.03.3-R1
ChrisVis
Hi martincarlson,
anymore infos on the scene? Screenshots?
Scenefile?
But as I am on R15 I think I would not be able to open it to try it here...
Hope I can help out somehow, rendered thousands of animation frames the last month.
Cya,
ChrisVis
C4D R15 - C4DOctane 4.0 | Win7 64 | NVIDIA 417.22 | EVGA GTX 980 Ti SC | EVGA GTX 780 Ti SC |EVGA GTX 780 Ti SC
i7 4930K 6x4.3GHz OC | 64GB | ASUS P9X79-E WS
+ Netstor Turbobox 250A | 2x EVGA GTX 780 Ti SC + 2 x Palit GTX780 Ti 3GB | all watercooled
martincarlson
I don't get it.
This is my settings:
It renders the first frame. Tried both max samples and a time limit. First frame = ok. Then it just stops.
Here is when the first frame is finished. The whole thing stops.
I've tried Resend whole scene, and the other alternative. Same thing happens.
make a clean scene and copy all content. try again
martincarlson
Ok. Will try.
moebius
Try to render in Render-Manager.
martincarlson
aoktar wrote:make a clean scene and copy all content. try again
Copied it. Same result. Renders one frame. Then stops.
This is with new 2.23.1.
martincarlson
moebius wrote:Try to render in Render-Manager.
What is render manager?
moebius
Look inside C4D for "add to Render-Manager". Menu > Rendering > Render-Manager...?
I'm sure it's the same name in my German than English
martincarlson
moebius wrote:Look inside C4D for "add to Render-Manager". Menu > Rendering > Render-Manager...?
Ok, Render Queue I guess it's called in english. Same trouble. One frame - then stops.
