Octane exporter for C4D version 0.07
abstrax
Hi all,
here comes version 0.07 of the Octane exporter for CINEMA 4D.
It fixes a few problems with the animation export dialog and adds support for camera motion blur. Keep in mind though, that camera motion blur is exported only during animation rendering not, when you click on "Render". I also added back the Russian strings translated by Mantra.
These are the PC builds of the plugin:
CINEMA 4D R9.6 (32/64bit):
OctaneExport_0.07_win_r9.6_release.zip
(173.39 KiB) Downloaded 438 times
CINEMA 4D R10.1 - 11.0 (32/64bit):
OctaneExport_0.07_win_r10.1_release.zip
(173.99 KiB) Downloaded 446 times
CINEMA 4D R11.5 (32/64bit):
OctaneExport_0.07_win_r11.5_release.zip
(252.64 KiB) Downloaded 489 times
These are the Mac builds of the plugin:
CINEMA 4D R9.6 (32bit):
OctaneExport_0.07_mac_r9.6_release.zip
(112.68 KiB) Downloaded 450 times
CINEMA 4D R10.1 - 10.5 (32bit):
OctaneExport_0.07_mac_r10.1_release.zip
(151.28 KiB) Downloaded 413 times
CINEMA 4D R11.0 (32/64bit):
OctaneExport_0.07_mac_r11.0_release.zip
(316.35 KiB) Downloaded 421 times
OctaneExport_0.07_mac_r11.5_release.zip
(346.06 KiB) Downloaded 449 times
Happy rendering :),
Marcus
jlc
Thanks!!!
clement
Thx Marcus :) !
Win7 x64 / Cinema4D R15.064 / I7 4930K - Nvidia gtx770
Domingus
great to see that there is some development going on here...
mat536
Thank you very much!!
Mark
Core i7 920 - 2.67 GHz | Win 7 Pro 64Bit - 12 GB RAM | GTX275-896MB - driver v.197.45 | 150 GB Raptor 10K HD | Octane 1.022 beta 2.2 |
ribrahomedesign
hi abstrax
i have crashes all the time ,
when i export the scene the first time to edit the material in octane,it export it perfect
but every time after i save the scene and return to cinema for the animation rendering
octane crashes
cheers
Rico
Windows 7 , 64 b / GTX 590 / Archicad 15 , 64 b / Cinema 4D R 13 studio , 64b /Intel(R)Core(TM)Extreme3,20Ghz /always latest Octane.
abstrax
ribrahomedesign wrote:hi abstrax
octane crashes
cheers
Rico
I sent you a PM. Let's find out, what the problem is.
Marcus
ribrahomedesign
hi abstrax
it is not working ,and i tryed to send you the file but that is not working as well ,slow internet.
i have to try to find out whats wrong with this scene ,bit by bit ,maybe a material,the scene is
not big enough to overload the GPU
thanks
Rico
abstrax
thanks
Rico
Could you try the following: First add a simple sphere object to the scene and disable everything else. Does the relinking work? If it does, it must be one of the objects/materials. Close Octane and don't save the Octane scene file and enable one object/branch after another until the problem occurs again. Then copy the object/branch into a new scene and check if you still can reproduce the problem. If you can, try to send me the file again, which should be now considerably smaller.
I sent you another option via PM.
Sorry, that you have to go through this tedious process, but I don't see any other possibility. Does the problem also happen if you use the render button instead of rendering the animation?
Has anyone else similar problems?
Marcus
ribrahomedesign
it does happend with render as well.
will try to do what you said
thanks again
BTW i dont think it is a exporter problem
Rico
