face_off wrote:Does it crash if you have started the plugin and done a render? Yes
Does it crash if you run Poser as Administrator? No
Thanks Uwe. My best guess is that Octane is trying to save your Network render settings, but doesn't have access rights to the appropriate file.
Can you pls open then close Poser (which will crash on exit) and send me the octaneplugin.log file.
Also, when NOT running as Administrator, does entering and exiting the Network Render settings crash Poser?
"change all materials on this particular geometry to Diffuse in one go"
Deane - are you able to detail in what situation you need this pls? Also, have you seen the GLOSSY_DIFFUSE_RATIO setting in the OctaneDefaults.py file?
Paul...
The attached video should hopefully explain what I mean.
The geometry items for "C07-Bottom" are loaded with a glossy node by default as the video shows.
I have to change each of the sub-geometrys to 'Diffuse' manually by picking each one of them... video
So what i'd like to be able to do, is pick the 'Mesh' say and right click and change all nodes to 'Diffuse' in one pick.
Notice also the refreshing of the Material Tree with each individual change to diffuse manually, this is the flashing of the tree I was talking about earlier.
Hope this explains what I mean...
And... where do i find that "OctaneDefaults.py" file again... hate Windows file structure.
RAM: 64GB
OCTANE PLUGIN VERSION: 2022.1..1.302 Prime
DAZ STUDIO VERSION: 4.21.0.5 Pro Edition (64 bit)
