So, as everyone has already said XXX all the way
cheers
brasc
not everyone...brasco wrote:Just to hammer another point home - TitanZ is Kepler, TitanX is Maxwell these are different architectures so saying it has "more cores" is totally irrelevant here.
cheers
brasc
On watercooling you can space them together and you can add 4 Z's like you would add 4 X's.. Z is then still a winner on performance.
that's another ballgameglimpse wrote:On watercooling you can space them together and you can add 4 Z's like you would add 4 X's.. Z is then still a winner on performance.
badly want to get that X & cut the balls out =) with single slot mod..Think I'll do some practice on my Black soon (already made mind to experiment on it =)
So in theory, playing a bit with tools, You can get TitanX as single slot card =) we've dreamed out with Smicha 'bout putting multile of those into some workstation motherboard allowing 7x cards =)
Absolutely, everyone has their own scenario.rappet wrote:not everyone...![]()
Maxwell, Kepler, whatever... performance counts, no?
So favouring one card all depends.. depends on config build possibility.. i.e. can you add 4 GPU, 3 GPU, only two... depends on wanting one slot space between the cards... depends on having watercooling or aircooling.. and more.
If you would force me to explicitely favour one card, it still would be the Z!
I just prefer the winner in renderperformance and I like the one slot space between the cards when aircooling.. then the Z is a winner.
OK.. when you need the 12 vram, then the X is a winner, but that is not needed in 95-99% of the projects, is it?
So, my definite choice is a lot of Z's and one or few X for the 5-1% of the projects.
I ran a benchmark (PT, PT power 0.3, 8000 samples) during typing and this is the result of rendering with only X, and only Z in the same PC, so very very comparable!
X: 9.4 Ms/sec- duration 8:32sec
Z: 14,2 Ms/sec- duration 5:28sec
greetz,
yeah, you are right, then I agree... theoreticallybrasco wrote:...
However, this thread is asking about 2xTitanZ vs 3xTitanX in which they are the same price and you get the small bonus of 6GB with the Xs and they're faster. So, like you, I'd like to go where the performance is better which in this case is the 3 x TitanX.
If we were talking about a single Z vs single X and you were space limited, then it is a lot easier to say go for the Z.
cheers
brasc
I doubt that... doing some math on my benchmark recalculating the seconds it is appr the same,brasco wrote:That's not in theory though is it?
3x Titan X are faster than 2x Titan Z - In practise.
cheers
brasc
Yeah, I agree, on air you'd definitely want space around the back of the cards, they draw air from the front to back, so they stack nicely I get ~5% temp increase on the middle card.rappet wrote:I doubt that... doing some math on my benchmark recalculating the seconds it is appr the same,
and are 2 Z's bit faster (164 sec versu 170sec).
And this is in a case where they both have good space to breathe.
In practise stuffing them in my other case 780T with only 6slots on mobo.. then the two Z's have good air to breathe, and the triple X will be stuck together.. then the two Z's with breating space will perform better then triple X getting too hot.. that is my guess... I wish I could practice this by having triple X![]()
So, again.. it all depends. If I only had this 780T case twith mobo 6slot..double Z is definitely favour.
In another build with enough space for triple X, the triple X would be preferable.
cheers,
