Live viewer stops working
sdanaher
Still getting problems where LV will just die and I have to restart Cinema. Usually after launching a final render to PV, which disables LV refresh. Seems to make that permanent sometimes :(
Windows 10 - 64GB RAM - Cinema 4D R20 - RTX 2070 x3
i couldn't understand what happens on your. We don't see this problems as you describe. Do you see any error messages?
sdanaher
aoktar wrote:i couldn't understand what happens on your. We don't see this problems as you describe. Do you see any error messages?
No, spinning beachball so can't check. Just happened again - not sure if stopping a PV render manually causes the problem, as opposed to letting it finish. It didn't hang when I let a couple of animations render, but just has after stopping the last one mid way through.
LV doesn't update, so I try clicking resend data and thats when it beachballs and I have to force quite Cinema.
