To those with a xpander.
Roughly do you think a xpander with 2 gtx 480's is capable of rendering a 30 second 512x384 animation in under 12 hours?
Xpander speed question?
You should have no problem with that, but a lot depends on the specific scene. Also how many frames per second you are using for the animation. Then it would come down to how long it takes your host app to export each frame and re-launch Octane each time (you could lose a lot of time each frame with this and it has nothing to do with the gpu).What kind of times are you getting with a single gtx480, if you have one that is.
System 1: EVGA gtx470 1280Mb and MSI gtx470 1280 in Cubix Xpander for Octane, AMD 945, 4Gb Ram
All systems are at stock speeds and settings.
It is still up in the air, but I hope so. RIB and/or Collada should enable Octane to see all of the animation data in one file, but a lot depends on how they plan to implement those formats. Try setting up a RamDrive like Radiance has suggested as that will make the process a lot faster. I will be trying it for my competition entry which I will be starting to render next week.
adrencg wrote:My only concern with video card rendering is how much they can take for long periods of time. Are vidcards built to run at full throttle for hours and hours?
I have the very same concern and that has me a little worried considering we just got two xpanders with gtx 480's that need to render pretty much every night.
Well I've had mine running at full throttle for days at a time without any issues. The XPander units really make this nice as they cool the cads very well. I am sure if you are overclocking the cards then you might run into issues, but htis is not recommended to begin with when using Octane.
Hi,Carl S. wrote:adrencg wrote:My only concern with video card rendering is how much they can take for long periods of time. Are vidcards built to run at full throttle for hours and hours?
Hardware is designed to run 24/7.
the GPU cards are, given a good cooled environment, made to run 24/7 at %100 load.
the cubix boxes are probably the best cooled boxes of all as they have a HUGE fan dedicated purely for the GPUs, with a propper front to back airflow, so i dont expect any issues there.
just make sure you're room does'nt get too hot in the summer, install airco systems if you're doing a pro job and want to play it safe.
Radiance
Sorry to hijack this thread:
Can this device work with a mac pro under win xp pro?
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10 64
NET RENDER : MB ASUS P9X79 - Intel i7 - Ram 16GB - Two RTX 3080 TI - Win 10 64
