HELP ! ... Problem with render setup (texture)
Lightcraft
We have technical problems with the set up. We kindly ask you for your help.
We attached the screenshots which help you figured out, whats the problem.
1) Comparison of V-RAY and octane Renders.
2) Preset of the all settings.
We have a problem to reach the rendering as it is in reference (V-RAY). WE have problem with mixing the bump, normal map and displace. The quality obtained from the Octane is not as sharp and accurate as it is in V-ray. We hope you will figured out what is missing or whats wrong in the preset . We just started use this program.
Thank you !!
akira
Hi, it seems that the specular value of the glossy material is not high enough to reflect IBL, and you may need a higher index value for it as well.
Return to “Autodesk 3Ds Max”
