Watercooled octane render workstation TITAN+3x 780 6GB
rappet
Went through this thread again from start looking at the pictures only... what a joy and learnful!
Again, thanx for sharing!
Will you do some sleeving? White might suit this build well :D
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
smicha
Thank you guys.
As for sleeving - I will (or get Bitfenix extenders, same I got for 2xZs for Piotrek). Enermax PSUs have terrible cables even for custom wiring. http://mainframecustom.com/ emailed me that redoing all wirings for Enermax PSU may cost more than PSU itself. So I think that 8 and 6 pin extender from Bitfenix is a great solution and HQ. I bought a crimper already and in future I'll do all custom wiring. There are great companies that sell wires, sleeving,... http://en.mdpc-x.com/mdpc-sleeve.htm.
rappet
smicha wrote:...
EK-FC Terminal TRIPLE Parallel
Image....
Hey Smicha,
This thread is a big value for information and inspiration!
I was looking at this beauty photo,
And since that I am learning about wc since recently ;) ...
I wondered if there is any quality difference for triple bridge in CSQ Plexi or black POM Acetal ?
Parallel is better then serial? ... coz' the liquid does not go from card to card to card, but with three seperate ways, and therefor the incoming liquid has same temp for all cards. Right?
I guess this has benefit in the beginning of flow starting, because I have read that after a half an hour or so, the temps in the whole loop will be about the same, right?
Is there a benefit for serial bridge? Is the flow not better with serial compared to parallel, because it does not split threeway?
If true... Why have you chosen for parallel over serial?
Greetz,
smicha
1. If flow is good parallel gives better temps over all cards - go with it provided flow is good, loop is well designed.
2. For your Bitspower waterblocks for Z you cannot go with EK bridges - use BP acrylic links (go parallel).
http://cdn.overclock.net/b/b6/900x900px ... 23011.jpeg
rappet
OK, thanx...
What a tempsYou got there!
smicha
These temps were actually over constant 3d modelling in modo and rendering as preview (up to 100 samples).
But at Idle and without Octane usage temps are lower and fans are set to possible minimal speed.
ChrisVis
Hi guys,
i can confirm, that serial loop for triple or quad GPU connection is not good... go for parallel. I also thought of the water flow, but it seems to be better to have less flowing water through all GPUs at the same time, than having faster flowing water going through one card by another... the last card definetly will always be the hottest. I got temp differences of +15 degree for the last card.
Cya,
ChrisVis
C4D R15 - C4DOctane 4.0 | Win7 64 | NVIDIA 417.22 | EVGA GTX 980 Ti SC | EVGA GTX 780 Ti SC |EVGA GTX 780 Ti SC
i7 4930K 6x4.3GHz OC | 64GB | ASUS P9X79-E WS
+ Netstor Turbobox 250A | 2x EVGA GTX 780 Ti SC + 2 x Palit GTX780 Ti 3GB | all watercooled
smicha
300mm res, more fittings, mayhems clear uv blue
smicha
My old Phobya 560 died and is replaced by Black Ice SR1. The rad is 9 FPI which makes it silent with NB PL2. The side for push has greater distance to fins, which makes it quieter. The only drawback are 4mm diameter screws (3mm are standard), and there are only 16 longer of them (shall be 32 for push-pull: 16 - 30mm, 16 - 35mm). I could not use great noiseblocker screws - had to buy 16x 35mm long ones (4mm diam.) My general impression is that SR1 is a very good rad (with about 2350W-2500W capacity), decently priced (I paid 90EUR, bargain, 130EUR regular) but requires huge case, caselabs SMH10, STH10. (I still value airplex as the best on the market, although with heavy a price tag).
Temps under OC to 1250mhz on core and 7000 memory are 45C at 800-900RPM of NB PL2. BTW the single 480 airplex radiator managed to cool 4 gpus to about 52C (not OC), but fans were set to their full speed (1400RPM). With the 560 rad temps are about 10C lower and fans are spinning 40% slower (silence).
itou31
Only one word : beautifull !
My rig is like garage mess compared to yours !
I7-3930K 64Go RAM Win8.1pro , main 3 titans + 780Ti
Xeon 2696V3 64Go RAM Win8.1/win10/win7, 2x 1080Ti + 3x 980Ti + 2x Titan Black
