Hi guys,
i'm very glad to see some MAXON presentations in NAB2015 which contains the Octane. It's here, www.c4dlive.com for someone who wishes to watch.
Version 2.22.2 - TEST3 - Updated on 03.04.15
aoktar wrote:I can ask for a way to interrupt, but i suppose that's not easy to implement. Personally, i prefer to have a faster compilation on geometries. This would be a big gain for each plugins.momade wrote:ok. any chance that stoping render on compiling will be changed in a future stand-alone?
when using high-computation stuff like massive discplacement or motion blur with 32 time samplings per frame or super high poly trees instanced 100.000 times, stopping the render takes 20-30 seconds. if passes are enabled even longer. any way to speed this up?
i agree.
having 4 gpus. i like to use i.e. two instances of c4d parallel with 2 gpus each, when rendering a bunch of similar stills with different material setups. sometimes one c4d renders wired pictures like it gets mixed up with the other c4d... materials or lights/hdrs seem to move over to the other renderfile. anybody else having the issue?
Hi,momade wrote:having 4 gpus. i like to use i.e. two instances of c4d parallel with 2 gpus each, when rendering a bunch of similar stills with different material setups. sometimes one c4d renders wired pictures like it gets mixed up with the other c4d... materials or lights/hdrs seem to move over to the other renderfile. anybody else having the issue?
i'm not use 2 c4d instances , but sometimes i have stranges horizontales stripes in picture viewer (never happened like this before 2.2 ), its like 2 renders are mixed.
i ll try to post a screenshot...
anyway i ve just updated from 2.14 to 2.22.2 ,i know i come after the "battle", but it is normal that the f-stop and aperture sliders are sync and move both together?
pxlntwrk.net
pxlntwrk.net
This glitch was here in 2.21 or 2.22 early versions. Have you tryed with 2.22.2 test3?pxlntwrk wrote:Hi,momade wrote:having 4 gpus. i like to use i.e. two instances of c4d parallel with 2 gpus each, when rendering a bunch of similar stills with different material setups. sometimes one c4d renders wired pictures like it gets mixed up with the other c4d... materials or lights/hdrs seem to move over to the other renderfile. anybody else having the issue?
yes i've just updated from 2.14 to 2.22.2test3 , i've not use earlier since 2.14.
And for the aperture and f-stop sliders sync ?
pxlntwrk.net
pxlntwrk.net
hmm, interesting. We don't see the glitches anymore. Can you post a screen shot?pxlntwrk wrote:Hi,
And, yes both sliders are going together as in last Standalone.
Thanks for speedy answers...
i ll try to post a screen ..
pxlntwrk.net
pxlntwrk.net
Here, kind of glitches i have sometimes in PV since i have updated from 2.14 to 2.22.2 t3 ( never happened like this before )
pxlntwrk.net
pxlntwrk.net
Does this also happen, if you disable network rendering?pxlntwrk wrote:Here, kind of glitches i have sometimes in PV since i have updated from 2.14 to 2.22.2 t3 ( never happened like this before )
