Octane for Softimage 1.02 RC12 [Obsolete]
wireframex
Hey Face
What do you think about Octane 3.0 Volumetric rendering ?
Is it possible to support it in next release for SI ?
Phil
Main Computer:
Ryzen 3990X / 96Go Ram / 2 x RTX 3090
OS: Windows 11 x64 - NVidia Driver 560.70 - Octane Plugin Build 2023.1.3.141
Licensed: Softimage 2012 SP1 / Lightwave 2024.0.1 / Rhino 8.9
face
Haven´t thought about it.
I also don´t know how it will be implemented inside the SDK.
If it uses only spheres as driver, it shouldn´t be a problem to include it over an ICE-Tree.
VDB´s will be more complex...
face
http://vimeo.com/user2509578
abeoctane
Hi face, do you have an estimated release date for an octane plugin update?, it is unusable in it's current state for animation, thank you.
face
abeoctane wrote:Hi face, do you have an estimated release date for an octane plugin update?, it is unusable in it's current state for animation, thank you.
I hope to release a new one in the next days.
face
Gescort
Hi, All!
Sorry for my English!
I created mini-addon for Octane for Softimage, that adds a visual interface for longitude and latitude selection.
Updated only connected Octane Daylight Environment node. OctaneDaylightSelection window may be scaled.
Currently I did not pack addon, for install you have to unpack this archive in c:\Users\[UserName]\Autodesk\[SoftimageVersion]\Addons\OctaneForSoftimage64\ where OctaneForSoftimage installed.
To open a OctaneDaylightSelection window, use View - Others - OctaneDaylightSelection.
Download OctaneDaylightSelection: https://www.dropbox.com/s/0icna8ox46ke2 ... n.zip?dl=0
face
Gescort wrote:Hi, All!
A cool extension!
Also a little news from me, nothing special ;)
face
400000 ICE instance cubes shapes.
Gescort
Great!
ICE instances, that is the best thing that I'd like to wait in the future!
wireframex
Hi Face
something new since 1 month ?
all the best
PHil
Main Computer:
face
wireframex wrote:Hi Face
all the best
PHil
Ice is nearly finished.
It is possible to use reference meshes which can be selected from a goup or as single mesh over the instance shape compound.
This implementation was simple.
I have also implement the possibility to work with all internal shapes ( Point, Segment, Disc, Rectangle, Sphere, Box, Cylinder, Capsule, Cone, Blob )
Point, Capsule and Blob will be converted into a Sphere shape.
This wasn´t so simple, i have included a base obj for each of the 6 shapes in the code.
Each PointCloud will have its own nodegraph.
In this graph i added one or more of the 6 basic shapes added a scatter on each shape and added it on a group and this to a geometry out.
The next step is to connect the ObjectLayer to the GeometryGroup which i have made by hand to see the resulting PointClouds.
I will also add a color to each shape, so that each shape can have its own color. This is limited by the old SDK
The current result will look like this:
face
wireframex
Interesting
Keep up posting for us Face :)
Main Computer:
Return to “Autodesk Softimage XSI”
