At first I had a pb similar to this one: http://render.otoy.com/forum/viewtopic.php?f=79&t=45410
As soon as I moved the mouse pointer over the ORVP (the generated image, to be precise) it crashed (both octane and carrara), even with empty scenes.
That has been solved by checking "Use priority" and "Auto Start Render", as Sighman suggested in the topic I mentionned (and I suppose by the 2.17.0068 version).
Now it works ... for simple scenes. For example, in the file scenes supplied with Carrara, "indoor\Afternoon.car" works fine, whereas "misc\HowiesSnowScene.car" don't work.
I load the scene, launch the ORVP, and it freezes immediately: the menu bar inaccessible, at the bottom it's stucked on "Compiling mesh...", the counters (Textures, Triangles, Displacement, Hairs, Meshes) are all stucked at 0, and a few seconds later the OS says it is not responding. If I cancel the msg and wait a few minutes, it responds again (still nothing displayed, all counters still at 0) but the menu bar is accessible again.
In the log there is that:
[17:24:49.203] ERROR : CUDA error 1 on device 0: One or more of the parameters passed were not within an acceptable range of values.
[17:24:49.204] ERROR : -> failed to bind texture to device memory (data2)
[17:24:49.204] ERROR : device 0: failed to bind data texture 1 of context 0
[17:24:49.297] Render Failure Callback
[17:24:49.488] Render Failure Callback
[17:24:49.688] Render Failure Callback
[17:24:49.888] etc ...
I rebooted the computer many times, re-downloaded and re-installing both the standalone and the plugin, uninstalled standalone 2.17 and installed 2.16 instead (and also 2.06, and 2.21.1), deactivated the anti-virus (including during the install). Nothing worked.
I'm all the more disappointed that with OctaneRender_demo_2_06_win64 it worked perfectly with this configuration (see below). I tried various scenes including heavy ones. Besides a few shaders not rendering correctly and carrara hair and fire not rendered at all (which, as I understood, is normal), I had no problem.
Any suggestions ?
My configuration:
CPU Intel Core I7 965 3.20 GHz
MB Asus P6T Deluxe
12 GB RAM
Graphic card Asus GTX Geforce Titan X - 12GB VRAM (driver v347.88)
HardDrive OCZ Vertex 4 - 500 GB (200 GB free)
Windows 8.1 64b
Carrara 8.5 Pro Build 243 - 64b
Octane render standalone v2.17 64b
Octance render for Carrara v2.17.0068 64b
