OctaneRender® for ArchiCAD 3.03.3 [OBSOLETE]
Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
BfPuVAK
Thanks for the info!
Wouldn't suppose "only" 2 GTX580 - and "only" 20h.
Must be well adjusted, both the system and the Kernel Dl - AO ;)
Artur
Win 10 Pro 64bit / Intel i7-6700 @ 4.0 GHz / RAM 32GB
2 x Nvidia GeForce GTX 980M 8GB (+ sometimes a GTX 970)
Archicad 21 4022 GER Full + Octane Render !
https://www.youtube.com/watch?v=7l7SefSWV98
http://www.youtube.com/user/BfPuVAK/videos
rappet
face_off wrote:Release notes for 2.20.0.36 are:
2.20.0.36
I have held off increasing the texturemap name length from 50 for the moment, since it relies on changing the format of the "default material" files, and some irregularities with this approach have been uncovered on one of the other plugins, so I want to get it working flawlessly before implementing this in the AC plugin.
Hi Paul,
(Working with 2.21 test now.)
Back to texturemap name length.. I am getting this error when saving the Archicad file,
but what is my problem working with these long texture names? It does nog save them to project file, but they are showed in the render!
greetz,
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
Proxy material name length is still set to the long 50 char limit. I will fix this in the next release (a day or two away).
rappet
That's good news and awsome if possible shortly... thanx ahaed :D
(just purchased a bunch of OBJ's I really would love to use for project I am working on right now)
rappet
face_off wrote:Below are links to a revised test build. As above - pls use with caution.
2.21.1.40
- Fixed issue where saving Octane data to the pla/pln was not reloading correctly
My apologies for the issues found in the previous 2 test releases.
Download Links
Download the plugin from the following links:
- OctaneRender for ArchiCAD 18 2.21.1.40 (64 bit)
- OctaneRender for ArchiCAD 17 2.21.1.40 (64 bit)
- OctaneRender for ArchiCAD 16 2.21.1.40 (64 bit)
Hi Paul,
I have opened a complex scene in 2.21 which I am working on in 2.16.
With 2.21 everything seems fine.
I tried to see the out of core texture working. I gues it starts to fill out of core whin gpu RAm is 100%, right?
When enlarging the resolution Archicad quick quit (had this earlier, remember).
I'll try again enlarge resolution in little steps to slowly fill Vram and see out of core get in use.
Or is there something else to fill out of core and spare vram?
'Use with caution'?
Should I better proceed with 2.16 for my project?
Is it still with lot of risks testing 2.21 with project?
greetz, Jeroen
edited: Filling up vram by enlarging resolution does not force to use out of core.
How does out of core work, and how can I test it?
rappet
And will that be in the 2.16/2.17 versions or in the test versions, or both?
2.22.2.41
- Compiled with Octane 2.22.2. Refer to Octane 2.22.2 Standalone release notes for details.
- Pin changes to the Thin Lens and Panoramic camera stereo settings
- Fixed issue where proxy material names has not been extended to 100 characters
- Limited the maximum render resolution to 8000x8000. Resolutions above this crash the ArchiCAD widget used to display the Viewport
* Due to the above issue, I have not been able to implement Viewport Zooming, since the ArchiCAD Viewport widget would run out of memeory once you rendered > 2000 x 2000 pixels
* Looked at implementing a Loading Scene dialog with a Cancel button, however the ArchiCAD Photorenderer already has a progress, and ArchiCAD does not support having more than one progress dialog window on the window at once, so this cannot be done.
The 2.22.2 version. The 2.16 version still has the old 50 character material name restriction.
rappet
Thanx for the new version. Super!
Garquitectos
Paul is the most efficient programmer in the world! Many thanks.
Octane Render for Archicad, Archicad 16 Spanish, Bimx. - Win 7 64 bits - Intel core i7 870 - 3,30 Ghz, - 12 Gigas Ram - GTX 660 + GTX 650 Ti
http://www.garquitectos.es
http://garquitectos.wordpress.com/
rappet
Garquitectos wrote:Paul is the most efficient programmer in the world! Many thanks.
Totally agree... This is the opposite of Paul:
And Paul, I guess you have good brand of coffee:
Return to “Graphisoft ArchiCAD”
