CUDA error 999.
AlexMakhov
Need help.
_______________________________
Started logging on 27.03.15 14:34:08
OctaneRender version 2.22 (2220000)
C:\Users\Alexandr\AppData\Roaming\MAXON\CINEMA 4D R16_14AF56B1\prefsoct.dat
Export materials time= 0.047 ms
Collect objects time= 0.024 ms
Meshes creation time = 1.8 ms
Octane voxelization time = 0.001 ms
Sending to Octane engine time = 0.09 ms
Total export Time = 106.938 ms
Export materials time= 0.038 ms
Collect objects time= 0.02 ms
Meshes creation time = 0.761 ms
Octane voxelization time = 0 ms
Sending to Octane engine time = 0.054 ms
Total export Time = 102.238 ms
Tried to access pin via an invalid ID P_INDEX (80)
Tried to access null node pin
Can't write float to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0000000011D043F0)
Tried to access pin via an invalid ID P_BRIGHTNESS_SCALE (17)
Export materials time= 4907.926 ms
Collect objects time= 7.285 ms
Meshes creation time = 2114.475 ms
Sending to Octane engine time = 47.675 ms
CUDA error 999 on device 1: An unknown internal error occurred.
-> kernel execution failed (pt)
device 1: path tracing failed
<<< Render Failure >>>
-> failed to deallocate device memory
-> could not get memory info
How much triangles is on your scene?
AlexMakhov
About 14 millions. But i was rendered this scene yesterday.
AlexMakhov wrote:About 14 millions. But i was rendered this scene yesterday.
well, you should stay on previous version. I think there is some extra vram usage on latest version. I'll report this.
AlexMakhov
With 2.16 version i have same problem. :cry:
Log:
Started logging on 30.03.15 09:50:45
OctaneRender version 2.16 (2160000)
id2:1
id2:2
id2:3
id2:4
id2:5
id2:9
id2:8
id2:12
id2:11
id2:13
id2:14
id2:15
id2:16
id2:17
id2:18
id2:19
id2:20
id2:21
id2:22
id2:23
id2:24
id2:25
id2:26
id2:27
id2:28
id2:29
id2:30
id2:31
id2:32
id2:33
id2:34
id2:35
id2:36
id2:37
id2:38
id2:39
id2:40
id2:41
id2:42
id2:43
id2:44
id2:45
id2:46
id2:47
id2:48
id2:49
id2:50
id2:51
id2:52
id2:53
Prefs:C:\Users\Alexandr\AppData\Roaming\MAXON\CINEMA 4D R16_14AF56B1\prefs\oct.dat
Can't Read Preset File: C:\Program Files\MAXON\CINEMA 4D R16\plugins\c4doctanepresets.dat
Tried to access pin via an invalid ID P_INDEX (77)
Can't write float to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0000000011BE7650)
Tried to access pin via an invalid ID P_BRIGHTNESS_SCALE (15)
Export materials time= 4403.042 ms
Collect objects time= 7.956 ms
Meshes creation time = 1992.587 ms
Sending to Octane engine time = 30.96 ms
-> kernel execution failed (dl)
device 1: direct lighting failed
-> failed to deallocate device array
-> failed to unload module
Total export Time = 54340.59 ms
-> failed to bind device to current thread
device 1: failed to initialize resources
CUDA error 999 on device 0: An unknown internal error occurred.
device 0: failed to initialize resources
No need to post zillions lines. It shows a cuda error, and not a plugin problem.
You should detect what causes this error. Most propably it's out of vram problem, second possibility hitting to polygon limits.
NVN
14millions Polygons or Triangles?
Octane can only 8.5 Million Polygons!
AlexMakhov
Octane can ~19 millions triangles.
Alex, what version cuda drivers do you have installed?
AlexMakhov
face_off wrote:Alex, what version cuda drivers do you have installed?
CUDA 7.0
