Motion Blur and Multipass
Ah ok! We don't put releases before doing stable enough. Dayly builds can be found in this section.
Postyr
So, i tested it with 2.22.0 and it seem to work as intended. Motion blur is disabled for all layers when you activate multipass render.
Postyr wrote:So, i tested it with 2.22.0 and it seem to work as intended. Motion blur is disabled for all layers when you activate multipass render.
try 2.22.1. Should work if you select "distributed ray tracing".
