+1, I also would like this feature.oguzbir wrote: The reason is similar why we have clay rendering node in the first place.
That way we can produce our custom passes Which will create great flexiblity in renders.
Maybe a bad example but...
Imagine a heavy scene with lots of different materials and 1000's of objects
- rendering all scene objects with same reflection roughness
- or rendering a clay-like render with custom colors maybe with some reflectivity..
Main idea behind this is doing that as an override will enable to have all objects' materials intact in a large scene.
This might be somehow easy to do in standalone but in 3dsmax it's a pain really.
You have to save where your materials are store and have different versions for same file with one material assigned to all objects.
please add this feature..
I used to use this with vray all the time.
OctaneRender™ Standalone 2.22.2
- Rikk The Gaijin
Ok, I have been fiddling around with the specular material trying to improve things. Turns out, that the Fresnel reflection that is being calculated is too bright. It is like all light is polarized perpendicular to the reflection plane (in reality it's usually a mix). I fixed that and also tried to improve the internal reflections. Tell me what you think (the left glass is rendered with 2.21.1, the center glass with 2.22 and the right glass with the (hopefully) improved specular material):itsallgoode9 wrote:good to be able to have the option if needed thoughmanalokos wrote:There are no unreflective surfaces, a specular material without reflection is not realist.for real though, the purpose of this feature was to be able to lower the reflectivity of specular material, which are very low at normal angles. water, for example is around 2% at normal, which if you set Octane to do this, it would SEVERELY darken the glass material.
Reflectivity = 100% (transmission is always 100%): Reflectivity = 80%: Reflectivity = 50%: Reflectivity = 20%: Reflectivity = 0%:
- Rikk The Gaijin
The one on the right looks nice, if you ask me.
- Elvissuperstar007
- Contact:
http://c2n.me/3eUiCr6.jpg ID layers bug
The right one for sure !!abstrax wrote:Ok, I have been fiddling around with the specular material trying to improve things. Turns out, that the Fresnel reflection that is being calculated is too bright. It is like all light is polarized perpendicular to the reflection plane (in reality it's usually a mix). I fixed that and also tried to improve the internal reflections. Tell me what you think (the left glass is rendered with 2.21.1, the center glass with 2.22 and the right glass with the (hopefully) improved specular material):itsallgoode9 wrote:good to be able to have the option if needed thoughmanalokos wrote:There are no unreflective surfaces, a specular material without reflection is not realist.for real though, the purpose of this feature was to be able to lower the reflectivity of specular material, which are very low at normal angles. water, for example is around 2% at normal, which if you set Octane to do this, it would SEVERELY darken the glass material.
Depending on the file format and Photoshop and the import plugin, the alpha channel needs to be pre-multiplied. You will find the corresponding option in the imager settings.Elvissuperstar007 wrote:http://c2n.me/3eUiCr6.jpg ID layers bug
To simplify things, we are developing the Photoshop workflow plugin for version 3, so you don't have to think about these things anymore in the future.
- Elvissuperstar007
- Contact:
http://c2n.me/3eURDGi.jpg
no aperture
no aperture
- no aperture.rar
- (1.37 MiB) Downloaded 305 times
If you use the camera of the Alembic file, you have to export the aperture into the Alembic file. In the imager you won't the aperture, that's for sure.Elvissuperstar007 wrote:http://c2n.me/3eURDGi.jpg
no aperture
- Elvissuperstar007
- Contact:
http://c2n.me/3eUWdvK.jpg dirt not work
