Render Layer Mask
nbeyond
Hi there =)
i´ve got a problem with the render layer mask!
Always stops by rendering the layer mask at 127. and i don´t know why =/
greez
armin
tomabobu
I think it's a bug in 2.21. Try to uncheck "Start after beauty".
Cinema4D R17 / Windows 7 on Intel i7-3930K / 32 GB Ram / GTX 670 / GTX 780 / 3 x GTX 970 on Amfeltech expansion cluster
tomabobu wrote:I think it's a bug in 2.21. Try to uncheck "Start after beauty".
yes correct, please try 2.22
nbeyond
thx - tryed 2.22 the render of the layer mask get finished but it´s just white/empty Oo
All objects are on ID1 by default. Set id2 for your objects. Watch render layer tutorials by inlifethrill if you missed.
nbeyond
now it´s just black.... -.- and if i set the layer Id to 3 (or 2 doesn´t matter) i don´t even get a picture!
kinda annoying - just to set up such a simple task cost me a lot of time by now... and the worst is never be sure if it´s my mistake or just a bug!
have you selected "Resend only updated objects" in render settings?
nbeyond
No - should i?!
if i select it i got this... at least a alpha channel ^^
but still no layer mask =/
nbeyond wrote:No - should i?!
yes of course. If you don't select this method all objects will be collected a single mesh. Will loose all object properties. You should watch some tutorials to understand differences of methods. Octane does not works as other renderers. It works as STATE ENGINE and this methods are important. Without understand how works, you'll have lot of problems.
Can you test this scene? Or send your scene to check.
rendermask-sample1.rar
(179.3 KiB) Downloaded 122 times
nbeyond
copied the whole project into a new one and now it works... don´t ask me why! ^^
But still THX for the help! =)
