Backlit Rice paper [SOLVED] [PROJECT FILE]
dotcommer
Yeah, I've tried camera visibility tags already, both in octane and C4D tags. I think the issue is its just a ton of light being emitted and being reflected in such a small space. I don't have any specular or reflections on this texture though so I don't know how to reduce the glare any other way. I'm not sure if I need to look into another way to produce this backlit effect. Maybe SSS instead of just a transmission texture? I don't know yet, but its killing me because it is looking really good, just when you look at it from any angle other than dead on, you get that terrible hot spot.
Thanks for the suggestion though!
Download my free Octane resources!
Paper Lantern | Fresh Snow (C4D Only) | Keyboard Displacement Texture | Solar Panel Texture
Mac Pro (2012) | 2x6Core 3.06GHz | 64GB | 1 x Titan Black 6GB
Portfolio: http://www.deltawavefx.com
tomabobu
Can you post the scene so I can try to find a solution?
Cinema4D R17 / Windows 7 on Intel i7-3930K / 32 GB Ram / GTX 670 / GTX 780 / 3 x GTX 970 on Amfeltech expansion cluster
dotcommer
tomabobu wrote:Can you post the scene so I can try to find a solution?
Certainly. Unfortunately I'm away from my computer today. But later tonight I'll upload it (was planning to share the scene anyway once I got the look down).
dotcommer
We're in luck! I was able to remote access my comp and upload the scene file. Take a look.
http://www.deltawavefx.com/uploads/back ... e_test.zip
tomabobu
No luck. I couldn't get the light from one side to be transmitted on the other side without attenuation. The rice paper is so thin that the amount of light on one side is very close in value to the amount on the other side.
See the attached, fake solution, that doubles the paper geometry to darken the diffuse on the interior.
backlit_texture_test.rar
(6.25 MiB) Downloaded 326 times
Your dimensions are looking very big. You should work on real world sizes to get more realistic results. See my tests
Paper_Tests_v03.rar
(140.04 KiB) Downloaded 374 times
dotcommer
Ahmet, your test looks to be the same size as my lantern. And it has the same issue as mine: blown out on the inside. I'm not understanding what your test file is showing. Do you mean project scale? I'm working in centimeters right now.
Do you think SSS on the paper texture might give me a better result? Maybe letting more light through the paper without having to increase the light source intensity so much?
dotcommer wrote:Ahmet, your test looks to be the same size as my lantern. And it has the same issue as mine: blown out on the inside. I'm not understanding what your test file is showing. Do you mean project scale? I'm working in centimeters right now.
your lantern's dimension was about 3 meters. I thought that should be problem. In my tests, i see the light source gives good effect on flat surfaces as in your example images. But on spherical geometry, illumination is more homogen. Wished effect is more visible only when light source is more close to surface.
dotcommer
SUCCESS!
Tom, you were almost there with your test. You just needed to increase the brightness, and add an Octane object tag to the interior pieces and set the visibility down a little. Aw man, this is great! I'm going to have some fun with this lantern now that I've got the look down. Tomabobu, thank you so much for your help on this! It renders really fast too. Just need about 200 samples and its clean! I was able to get a single frame of this lantern rendered in about 20 seconds. Not bad!
I'm uploading the "final" project files for this lantern so others can download and experiment with it, as a thank you to this awesome forum! Thanks to everyone who helped out with this!
_
Octane_Lantern.zip
(1.52 MiB) Downloaded 865 times
ten
Nice one DC. Thanks for sharing the results. Will help the rest of us out in a similar situation!
ten
( PC ) i7 5960x octal 4.5ghz / 64GB / 2x Titan X 12GB / 1x 780 6GB - ( Laptop ) i7 4790k 4ghz / 32GB / 980M 8GB - Octane CD4 2.x / C4DR16.x / win 8.x
