IPR flickering - build 2.16.0
electric_eric
I've just updated my octane plugin to 2.16.0 (windows) with lw 2015.1 and I'm getting a constant flickering in the IPR window.
I've updated my GPU drivers to the latest but I still have the flickering.
Any ideas?
Thanks.
Intel i7 6700k - 64gb Ram - 6 x 980ti
juanjgon
Do you have the same problem that you can see in this post?
http://render.otoy.com/forum/viewtopic.php?f=36&t=45332
What windows and nvidia drivers do yo have?
electric_eric
Yes I have this exact problem as in the posted video.
Using windows 8.1 and nvidia driver 347.52.
Thanks.
electric_eric
I should also note that I've using windows 8.1 and octane for a while (build 2.13.2) without any issues.
It's since updating to 2.16.0 that I have the issue with IPR.
electric_eric
Just tested the Beta build and the flickering IPR is no longer an issue with a simple scene containing a ground plane and sphere. Loaded a more complex scene with 373 objects and only 55mb of textures and the flicker IPR is there.
chris_solo
as for me I tested with different size preset from the IPR window and preset by default makes only one flickering and after no problem
as for the other modes : custom or size defined video format, example : 1024x768 there is this problem...
Perhaps this will help :)
Chris
electric_eric
Good tip, thanks :)
juanjgon
Please, can you test this new build of the 2.21 plugin? It is for LW 2015 Windows x64. You need to install the last beta plugin (2.21.1) and replace the plugin .p file. At least in my system it is working fine now.
https://www.dropbox.com/s/5nyvmjaiuuybx ... x64.p?dl=0
electric_eric
Ok I tried replacing the plugin and it fixed the flickering issue :) Many thanks.
The IPR info text flickers and will sometime disappear completely for a good few seconds though.
Return to “Lightwave 3D”
