OctaneRender™ for Blender 2.21.1 - 7.7 Win [OBSOLETE]
JimStar
OctaneRender™ for Blender plugin. Windows x64 version.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one. To stop the server - just right-click its icon in the tray.
  • Improvemed the Preview-Render scene loading speed.
  • Fixed the OpenSubDiv bug: sharpness value was loaded only after first change.
Blender Octane Edition - 7.7 (2.73 (59.1MB autoinstaller file)
Octane Server - 2.21.1 - 7.7 (10.5MB autoinstaller file)
DEMO is available. Use the same Octane edition of Blender for DEMO version of OctaneServer.
Octane Server DEMO - 2.21.1 - 7.7 (9.0MB autoinstaller file)
vipvip
thanks for this
The motionblur problem i was talking of on the last release post still remains
dafassi
Thank you!
I want to ask if it will be possible to use mutliple UV-Layouts (different textures) for one material in future-versions?
Greets!
WIN7 64bit • 32GB DDR5 RAM • Intel i7 6x4GHz • GeForce GTX780 • Blender
voon
Thanks :) Just to bring the issue over from the last thread: the problem of unreleased GPUs after a render persists, they're staying at 50% load after a render.
Strangely, this doesn't seem to happen on my laptop with a GTX 770M. Here, the GPU goes back to 0% after rendering (checked with MSI Afterburner)
billkeane
voon wrote:Thanks :) Just to bring the issue over from the last thread: the problem of unreleased GPUs after a render persists, they're staying at 50% load after a render.
Do you get the same issue if you use cycles?
voon
billkeane wrote: Do you get the same issue if you use cycles?
Have to check with a blender standard build when back at home ... in holidays now for a week :)
JimStar
Next version HERE.
Return to “Blender”
