OcDS 2.1 PRE RELEASE 5th
Moderator: BK
kibbycabbit
leblancd wrote:
Stevenyang0430 wrote:
kibbycabbit wrote:I'm seeing pro/con between two. But then, they're both beta. We'll see how things unfold once they get out of beta.
So far, I'm enjoying Iray's results. Kinda slow but then it loads the materials correctly.. Maybe that's why it's affecting the render time.
Another one important part I like about Iray, FINALLY spotlights with barn doors so it can be either unbiased or biased.
The way of setting up materials is totally different... *sigh*
The material setup is different, yes.
Also, my results all look like Octane's "Daylight kernel", in that I can't seem to get any good SSS going.
It could be just me, but everything coming out of iray looks kind of flat.
Can you explain how Iray comes out to be flat? I'm fairly sure we can tweak the light setup. So I can try toy with it on Iray and see what you mean.
Daylight... Daylight environment... Hmm, do you mean Direct Light Kernel? To tweak flat appearance, try to play with AO (Ambient Occlusion) distance in Direct Light kernel. I use Direct Light with AO and adjust AO distance, wow it renders much like PMC but much quicker and minimal noise (or none at all!).
More pro/con to mention:
Octane Render has render passes. Each layer will recognize other layer's lighting. That's a quite powerful tool. I have yet to master that... I don't know if Iray supports it.
System #1: Mac Pro Early 2009, 12GB ECC RAM, Display: GTX 750 Ti 2GB (Maxwell) + CUDA: GTX 980 4GB (Maxwell)
System #2: MacBook Pro /w Retina 15", 16GB RAM, GT 650M 1GB
System #3: PC Windows i9 6 cores, 16GB RAM, RTX 2080 SUPER 8GB
leblancd
kibbycabbit wrote:
leblancd wrote: The material setup is different, yes.
It was my ignorance of something completely new.
Yes, I meant "Direct Light Kernel".
I also found a few things related to Iray in the content library for skin that, when applied, changed the attributes of the shader. There is "Iray Optimized Genesis 2 (Fe)Male MAT", along with other Iray enabled things. It worked out, and I was able to get SSS in ears/nose/etc.
ch0pper
render passes. are there with iray
W7 64 bit |I7-3970X | GTX 780 X2(6GB) GTX 780TI X2 | 64 GB DDR3 RAM
Real Skin & real hair for Poser / DAZ Studio OctaneRender/iray - coming soon
jimgale
Tried it on a few things. Seems to me like iray is awesomely better than nothing - but far far slower and less configurable than otoy. I absolutely require the speed. Thoughts? similar/different experiences?
Spectralis
jimgale wrote:Tried it on a few things. Seems to me like iray is awesomely better than nothing - but far far slower and less configurable than otoy. I absolutely require the speed. Thoughts? similar/different experiences?
In the DS beta thread on here some testers are reporting similar rendering speeds to OR. Maybe this depends on the scene and set up. If CPU/GPU are working together then this might speed things up compared to GPU alone?
ASUS Maximus VI Extreme, i7 3770k, 32GB RAM, 4 x GTX760 4GB, Win 8.1 x64.
Squirtle
On my system, Iray is at least as fast as Octane. I don't doubt that it might be slower on other machines though.
One thing you might try to get Octane-like speed in Iray is disabling CPU rendering in the Advanced Render Settings tab. I've heard word in another thread that some people are getting faster speed from Iray when it renders on just the GPU.
Desktop - Win 7, Intel i7-2600, GeForce GTX Titan X
Laptop - Win 10, Intel i7-3740QM, Quadro K3000M
ch0pper
it would seem that iray thread has been deleted oh dear , someone at otoy not happy about that. I take it
3dmania
Does IRAY use the default DAZ shaders? Or is there a seperate material setup, similiar to the NGE of Octane?
bmosalt
ch0pper wrote:it would seem that iray thread has been deleted oh dear , someone at otoy not happy about that. I take it
They've secreted it away in the Off Topic forum.
http://render.otoy.com/forum/viewtopic.php?f=40&t=45263
ch0pper
hahah i wonder why ? lol
Return to “DAZ Studio”
