Octane adds another frame for each frame rendered
coilbook
Hi after i rendered PNG sequence I got these pictures that are labeled the same except letter m is added SO noe i have duplicated PNG files one named c01_50.png (normal) and another called c01__m10050.png What can it be? And this is for every frame rendered I get this
coilbook
Here you can see I render one picture and I get 3 black and white also
noelnoel
i think its a render elements channel.
coilbook
noelnoel wrote:i think its a render elements channel.
Thank you for your reply.
I use 2.16 Do you know where can i disable this?
coilbook
I found it. Thanks a lot again you saved my day!
3dgeeks
Also, i find that pngs of zdepth seem to look like your image. Exr seemed to work better.
noelnoel
:D :D :D :D :D :D
Return to “Autodesk 3Ds Max”
