DOF highlights
Hi I noticed highlights in DOF do not get blur at all they stay sharp and STATIC NOISE does nothing it still moves chaotically in animations Image was done in AO at 3500 samples (720p) everything looks good but DOF highlights
Is that HDR lighting or no? At first glance, it looks like raising the sample rate on the light that is causing those speculars will probably fix this issue. Either that, or just let it render longer.
Specular highlights are complicated to computer in out-of-focus areas. Octane's DOF system is incredibly fast, except for with specular highlights which require special attention.
Win 8.1 / C4D R16 / Maya '16 / 5x GTX 980 Ti
Thank you for the explanationgarytyler wrote:Is that HDR lighting or no? At first glance, it looks like raising the sample rate on the light that is causing those speculars will probably fix this issue. Either that, or just let it render longer.
