OctaneRender for Carrara 2.21.0067 [Test]
Carrara (Integrated Plugin developed by Sighman)
Sighman
Are you using 3rd party props in your scene or do you have original content? If I could reproduce your scene maybe I can reproduce the issue. If you could send me the scene where you have replaced the commercial content with primitives then I could restore the scene on my end. A list of 3rd party props you used would also be useful.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
wendyluvscatz
I have a lot of third party props in it but it is a bit of a moot point
as the scene now renders with camera movement.
it was my first scene with the new build and everything has worked since,
it was only after reading SciFiFunk having a similar issue that I posted but it appears to have fixed itself.
A cleanout of my DAZ temp folder may have been all that was needed, I do that often, or maybe a restart, or the 40C Adelaide heatwave and having to monitor my temperature with GPU-Z and keep whacking on the aircon by the tower.
Win 10 64-bit CPU Ryzen 3 3600g 32GB RAM graphics RTX2080Ti
Sighman
New update posted to this thread.
EddyMI3D
Thanks a lot!
My Rig:
PC with AMD FX 8350 @ 4,00 GHz
Win 7-64
Nvidia GTX 760
Nvidia GTX 970 (only for rendering)
About 6 TB of disk space (768 GB of SSD)
Octane/Octane for Carrara
orion_uk
Hi Sighman :)
Hope I am not repeating or misiunderstanding as I have not been able to use my computer for a while, so am a little out of touch with latest builds and forum posts but working on that tonight ;)
Re: OctaneRender for Carrara 2.21.0067 [Test]...Well LRVP still says 2.21.0065 after installing?
Also, replicated grass on infinate plane, see image below....
Replicated grass on infinate plane.
http://www.Neil-Isted.com
Intel i7 870/2.93 GHz
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
OctaneRender™ for Blender
Ds pro
OR Standalone V4
Poser Plugin
Sighman
orion_uk wrote:Re: OctaneRender for Carrara 2.21.0067 [Test]...Well LRVP still says 2.21.0065 after installing?
Oops, my bad...
orion_uk wrote: Also, replicated grass on infinite plane, see image below....
Sorry, not supported. You would likely run out of memory anyway since each copy of the plane would have to be added to its own scatter. I'm not sure how many blades of grass you have replicated but imagine multiplying that by 40000.
Sighman
You can also simulate an infinite plane using a replicator with a grid pattern. I used a replicator and a plane for the base and I used a Replicator a Surface Replicator and a Sphere as my scattered object. This is the result:
Scatter Configuration
Scatter Plane
Scatter Plane
orion_uk
Ah, great idea Sigman thank you ;)
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
Ds pro
OR Standalone V4
Poser Plugin
Return to “Carrara”
